yeah that filler is awesome looking, makes it look more scale.My fav detail is the real fuel filler.
View attachment 49979View attachment 49979
These things just are, I accept that now.
bonehead looks like he does sum quality work there.Thanks a lot chaps, I’ve fitted the DDM HD rear springs now and it bottoms out at +2 feet now and now sags a lot less, well not at all now. Trust me this is a bit heavier than the standard buggy she once was.
The tires have an air gap because I have to use front foams in the rear. I reckon the tires will tear after a few full throttle runs but we’ll see.
I’m using hostile zero growth fronts on the rears because you can’t use rear foams with Trenchers, well you can if they are soft poop.
The first picture gives you the best idea of how much the tires sag.
I’m going to use black button heads with rear nuts on these.
View attachment 49983View attachment 49983
Thanks mate and yes Bonehead is quality at making carbon fibre parts.bonehead looks like he does sum quality work there.
PS: added ur updated photos to the favorite builds thread
Cool. If u can, a complete parts list with the parts coming for it would be very much appreciatedThanks mate and yes Bonehead is quality at making carbon fibre parts.
Let me know if you want a complete parts list because it’s long??
Basically after the GH stuff comes the only original parts will be the shock bodies, rear bulkhead, body mounts, and most of the PCSC.
Trust me the PCSC mod is the one for standard engine mounted engines regardless of power. You can even get carbon clutch discs now. You’ll never strip a spur gear again.
I know this seams extra but I’m going to plug these gaps with black mesh. It will help save headache in the long run. I know it’s even more weight but with 8.5BHP fcuk it.
View attachment 49991View attachment 49990View attachment 49991
Thanks mate, I know it's not to everyone's taste but its taken a few years to get all the parts together and now its a truck I'm proud of and it was such a blast to build now I can't wait to run it. I'll post vids when I do hopefully this weekend.Wow..that truck looks a bit special Milo?
Wow! U weren't kidding when u said there's like 1 percent original parts. Very nice parts u got on this! Thanks for the listOk so here's the list, I hope I've captured everything.
Kraken TSK1 Cage
Kraken V3 Chassis
Kraken Upper front hinge pins
Kraken Stainless Steel front shock shafts
Kraken Titanium Rear shock shafts
Kraken billet rear cage mounts (not fitted yet)
Modified RC rear chassis plate
Custom carbon sidepods
Threshold rezzies V2
Threshold Umbrella seals
Thicker o rings in shocks
DDM HD rear springs
HPI Standard front springs
Team Chase rear shock towers
TR Front chassis plate
TR Front shock brace
TR Steering servo saver thing
TR Rear top plate
TR Gearbox
TR Clutch V2
TR one piece brake mount
IRC Differential
DGI Steering turnbuckles
IRC Steering posts
Swingy P limit straps
RPM front and rear suspension arms
RPM rear bumper with modded HPI 5T rear bumper
IRP Heim joints
Fullforce Spring stand off's
Fullforce Shock socks
Reinforced bolts for hinge pins
Hostile adjustable rear hubs
Fast Eddy bearings
Fast Eddy front hub cone things
RS Fruitbat axle extenders
RCR Brakes
Bonehead RC chassis braces front and rear, hinge pin things
Bonehead RC Rear boot protectors
Phatdad Rear hinge pin brace anti squat 2 degrees
Phatdad engine and chassis braces
Phatdad dogbones and cups
Gabe Brown Engineering rear engine brace
HPI PCSC modded to accept any gears
Custom Titanium layshaft for the PCSC
Golden Horizon front hubs
Golden Horizon Rear shock brace
Golden Horizon front bulkhead, rear shock towers, supports rear A arms, front 5T body mounts. (Not yet fitted)
Killer RC clear Battery box lid
Killer RC power switch
Vapetex Life batteries
Futaba Tx/ Rx
Futaba RPM Sensor
Switchblade kill switch
Savox servos
Silverback wheels
Proline tires
UBER RC wheel nuts
Scott Finlay Pro MX 340 with mesh mod
Bartalone Torpedo exhaust
Bartalone coil spacer
MSD coil wire
Stage 8 header bolts
Team Chase Carb filter
Billet intake manifold and teflon gaskets
FID fuel filter
Outwares allround
Titanium fixing screws
Full kill throttle and brake linkage
I think that's all.
GH stuff arrived and I only ordered it yesterday.
Nice one fleabay and scamazon.
cool, the kraken light bar should look great on ur truckOk so a couple of items missed and ordered,
Fitted
MIP Exhaust gasket
On order, delivery in a few days.
Threshold shock collars
Kraken LED Light bar
Looks good ? definitely better than stuffing all of that into the radio box.I’ve mounted the lighting box where I want it now.
It will do, there is space in the batt box for it but some reason I can’t explain, I want to keep them separate and I have the space to do so.
Plus I don’t want astetic lights messing up crucial electronics.Looks good ? definitely better than stuffing all of that into the radio box.
Kraken TSK1 Cage
Kraken V3 Chassis
DDM HD rear springs
TR Rear top plate
TR Gearbox
TR Clutch V2
IRC Differential
IRC Steering posts
IRP Heim joints
Fast Eddy bearings
RCR Brakes
Futaba Tx/ Rx
Futaba RPM Sensor
Savox servos
Silverback wheels
Proline tires
UBER RC wheel nuts
MSD coil wire
FID fuel filter
Outwares allround
In all honesty this is first time I’ve made a complete list of parts and I’m sure I’ve missed a few things.If you don't mind me asking, How much was the order?
Challenge accepted ?In all honesty this is first time I’ve made a complete list of parts and I’m sure I’ve missed a few things.
I took me a few years to get all these bits and I’ve never kept track of how much I’ve spent. If I did I’d stop. Some bits were given to me some bits were bought in the states some from Australia and lots from the UK.
I reckon if you tot it all up it’s a lot, I’m not about to add it up but I’m sure if you want to you could go on DDM and a few other sites and work it out. Do me a favour though if you do please keep the number to yourself, well don’t tell me. ????
