Kraken TSK1 Rebuild
I’ve also installed the rear shock brace from GH racing. These are rare as hens teeth, I got this from Australia, last one anywhere and that was years ago. You can see the larger opening for the shock cap compared to the TR one and this will give better clearance for the Threahold rezzies.
49738
It’s a much more meaty item and it doesn’t need bushes.
49739
Here is the shock brace and fuel filter what a work of art. It’s over engineered but so what??
49740
49740
Lots of test fitting but I’ve run out of tubing, more on order.
49746
I’ve done loads more but I’ll post later.
Ok some more progress, I’ve installed all Futaba telemetry sensors on the engine, RPM and temperature. Apologies for the terrible pics. View attachment 49735
I’ve also soldered in the kill switch wiring and xt30 connectors, 16AWG silicone wire.
I’ve used high temp braiding to around the wire over the heat shrink.
Have you tried the rpm sensor and was it direct bolt in or you have to make bracket and what was the air gap for the sensor thanks for any info your build looks awesome
That's a nice fuel filter ?
I made the bracket from a piece of Mecano. The air gap is 1 mm or less and the manual says 1~2mm. I haven’t powered it up yet but might try today if I get time.
The fuel filter is from FID bought from RCModelz in the UK.
I’ve rebuilt my shocks with titanium shafts in the front and toughened steel in the rear from Kraken. Full Force stand offs and Threshold Rezzies V2s.
49751
I didn’t take the shock caps off because I didn’t have all the orings to replace them and they aren’t leaking so I left them alone. It meant that I couldn’t take the adjusters off to paint them so that will be for next time.
49752
So I’ve tested fitted the Torpedo pipe and in my best Russian accent, it’s problem.
49762
49763
I’ve ordered a 28mm copper slip ring coupling and some longer silicone tube. I thought about cutting the body mounts but thought better of it. It’s better to make the pipe fit the truck not make truck fit the pipe. Hahaha
You tried pushing the pipe into the header more right?
That's a 5b pipe Milo.
The mount is supposed to go under the chassis and the pipe sits further down, look at the angle of header to the pipe??
That’s what i thought when I took it apart trying to make it work.
I reckon my fix I have planned should sort it..........I hope.
What the hell, Wine, WINE ? All hoyty toyty. Now I know why you spelled Murican wrong . :ROFLMAO::ROFLMAO::ROFLMAO: Looking good Milo.
I’ve now mounted the exhaust it clears the cage as well now. I’m quite chuffed with the result. I used a bit of silicone hose as an insulator.
49802
I had a small disaster when I powered up the electronics I melted my switch.
49803
Turns out it’s a faulty temperature sensor so that’s going in the bin and I’m not ordering another. I’ll stick to my cheapo heat gun.
I’ve cut my carbon side pods to fit and I’ve mounted my carbon bead locks.
49804
49805
Getting there slowly.
Who makes them carbon beadlock?
