Yep, have to make a spacer for them to fit proper
As in new servo too wide doesn't fit into slot old servo came out of.don't fit as in ?
...height?
u'll need sum 2-3mm spacers if so? as per a 5ive?
Except the new servo case is just too wide for what I can only assume is the stock mount. Spacers aren't going to help that.Yep, have to make a spacer for them to fit proper
can u not file the opening so it'll fit?As in new servo too wide doesn't fit into slot old servo came out of.
I was talking about height, but I was running a savox 0236 servo for steering in my dbxl. Never an issue with it. Break out the grinder, you should be able to make it fit mate.As in new servo too wide doesn't fit into slot old servo came out of.
Got it in no grinding.....took some doing wow.I was talking about height, but I was running a savox 0236 servo for steering in my dbxl. Never an issue with it. Break out the grinder, you should be able to make it fit mate.
Thanks appreciate that.I had no issues installing killswitch's on spektrum radios and I have experience with killer bee (relic-1) and myself along with a few others here with dynamite k/s... need help pm me and ill walk you through it
Thanks I have their 2 speed but have yet to install and testI liked the fid stuff when I had a dbxl.
