New to forum and 5th scale
Excited Celebration GIF by Slanted Studios
He's going to tell you to get an olimat.
Look at the rcmax pipe
Engine is ordered. Installing HR inner diff cups new bearings and the FLM axels. Still haven't decided on a pipe yet.
That and the color...not another blue part on the whole truck
I got the grey colored ones.
I’ve just had a set of big bore irc delivered today, thought it was a full set of front 5t shocks is a direct fit. But I don’t think they are I’ve contacted them and there sending out extra parts to make them fit
Why on earth would you think that 5ive t shocks are a direct fit on a dbxl? There are numerous threads (which a Google search or a forum search would have reviled immediately) which detail this conversion.
What servo horn are you using for the steering?
FID push pull setup.
https://www.ebay.ca/itm/193601202223?hash=item2d1387e82f:g:7wAAAOSwQBdfIU5L
I've just fitted one front IRC 5t shock to the front of my dbxl so far. Had to drill out a larger hole in the FID shock tower to accept the mounting hardware supplied with shocks. Hopefully I'll have some testing in this weekend.
Went of this thread as few people have used front 5t shocks. Also they must fit if he’s sending out the “extra” (don’t know what they consist of yet) to fit them.
https://www.largescaleforums.com/threads/stiffer-shocks-springs.28069/#post-351867
The shock towers need modified, and all the mounting hardware for the 5ive t needs used as well as shimming the lower ball mount to take up the slack. Yes they are the same length, they do not mount the same.
https://www.largescaleforums.com/threads/how-to-5ive-t-shocks-on-dbxl.21690/
Again use the search function, it's the second thread that comes up. Actually @Rep732 should make it a sticky as this come up fairly often.
