Its all about the purple bud?Sweet bruh ??????
What’s the shelf life ?
And that fuel tank is a little intense for just Rc’s ain’t it ? ?
can't you run just normal pump gas on the bb's ?only time I've heard of running race gas was with a 90gt or s80 ? that's sweet AF tho crucial????So after reading a bunch on these big bore engines and talking to engine makers I've now ate crow and invested a ton into filling the tank? Really not about ethanol poisoning, but more on compression ratios and leaded fuel. No ethanol is just a plus?? Oh, I'm still running pump gas on the ?engines.
Higher octane for the higher compression ratios of the big bores. Supposedly runs better and cooler with the leaded fuel??Ok cool so what are the gains?![]()
?Not quite sure but I believe it's a long time. Due to the additives and no ethanol present. I'm assuming this 10gal will probably last a couple seasons for me. I only get to run on the weekends and this is just for the 5iveT and vekta. I wasn't sure if there would be enough space in the pail to add the oil.Sweet bruh ??????
That too? I couldn't believe they had a purp one.Its all about the purple bud??
I think it's all about the CR and leaded fuel.can't you run just normal pump gas on the bb's ?only time I've heard of running race gas was with a 90gt or s80 ? that's sweet AF tho crucial????
Be honest thats just for the Gixxer.So after reading a bunch on these big bore engines and talking to engine makers I've now ate crow and invested a ton into filling the tank? Really not about ethanol poisoning, but more on compression ratios and leaded fuel. No ethanol is just a plus?? Oh, I'm still running pump gas on the ?engines.
I really can't hear sh!t with these engines but noise? So trying to hear a ping is a little hard to do. I could pull the head and look for piston damage, which I checked on the 65, but not trying to pull the 50. From what I've read they reccomend 95+ octane and I only have 93 at best around me. Some cam2 would probably work also but that is hard to find also. Now if I run this and don't see any differences, I will probably go back to pump gas also. Just want to see if it idles different, throttle response is different, etc. I run my cars and document for all to see. Just taking you guys on my journey. I could stop if you want??Correct me if I'm wrong, but unless you're getting pre-detonation in the motor, running higher octane won't affect anything.
No don't stop ??I really can't hear sh!t with these engines but noise? So trying to hear a ping is a little hard to do. I could pull the head and look for piston damage, which I checked on the 65, but not trying to pull the 50. From what I've read they reccomend 95+ octane and I only have 93 at best around me. Some cam2 would probably work also but that is hard to find also. Now if I run this and don't see any differences, I will probably go back to pump gas also. Just want to see if it idles different, throttle response is different, etc. I run my cars and document for all to see. Just taking you guys on my journey. I could stop if you want??![]()
Yeah I've been running my 65 on pump gas too with what I think is running good but you know the old saying, "you can't miss something you never had." So who knows, it may run totally different with this snake oil? or not?No don't stop ??
@mark35 runs pump gas on his 71 alx I think ?
I'm going to put my guess in the pot, I'm saying you'll notice it in tuning and tune consistency and not a power gain per say. And maybe better throttle response. Idk , I just made all that up so ?Yeah I've been running my 65 on pump gas too with what I think is running good but you know the old saying, "you can't miss something you never had." So who knows, it may run totally different with this snake oil? or not?
The gas salespeople have really done an amazing job with their marketing by convincing the majority of the population that higher octane is somehow better for your vehicles. It's just marketing. Certain engines are designed to run on certain fuels. That's pretty much it. A lot of higher-end cars call for "premium" because they are designed to be run on that fuel. Now, you can take the same engine and tune it so that it NEEDS to be run on higher octane, but if you're taking the same engine and not changing anything but the fuel, it really shouldn't change anything else. Ever notice there's no "premium" for diesel? lol.I'm going to put my guess in the pot, I'm saying you'll notice it in tuning and tune consistency and not a power gain per say. And maybe better throttle response. Idk , I just made all that up so ??
You are 100% right, running a zen on 100 octane when you can run 92 or whatever shite , you probably won't notice a difference because it was made for the 92. But I'm more talking about the fuels quality, race gas vs pump gas, the race gas is likely better quality and more consistent from batch to batch. And there's no other crap added in , I'm the race gas, that the pump gas has in it. I'm no expert and I might be well of the mark though lolThe gas salespeople have really done an amazing job with their marketing by convincing the majority of the population that higher octane is somehow better for your vehicles. It's just marketing. Certain engines are designed to run on certain fuels. That's pretty much it. A lot of higher-end cars call for "premium" because they are designed to be run on that fuel. Now, you can take the same engine and tune it so that it NEEDS to be run on higher octane, but if you're taking the same engine and not changing anything but the fuel, it really shouldn't change anything else.
Yea, there is certainly a good amount of contaminates in pump gas, they can even have excessive amounts of water in the fuel if the station isn't very busy. However, fuel is very strictly regulated and other than adding things to boost the octane and having leaded vs unleaded and ethanol-free, there's not much to worry about. That's one reason you should try to avoid going to low-traffic gas stations. Their gas sits in the ground for longer periods of time. The busier the station, the more often they get refueled which means the gas will be fresh.You are 100% right, running a zen on 100 octane when you can run 92 or whatever shite , you probably won't notice a difference because it was made for the 92. But I'm more talking about the fuels quality, race gas vs pump gas, the race gas is likely better quality and more consistent from batch to batch. And there's no other crap that the pump gas has in it. I'm no expert and I might be well of the mark though lol
