Quick baja build #100
I was tired of waiting for the rcmax rod ends so made my own. 5/16 heim, used a IRC shock spacer as the OD of it fit perfectly inside the heim. Had to trim off about a 1/16" off the end to fit inside the hostile hubs. Also had to drill the RPM out a touch, but these worked awesome and are obviously much larger than the factory style.
First outing today, lasted 20 minutes which is roughly 16 minutes longer than all of last years runs ?.
But the wheel nut came off and ended it short, after further inspection the beads started coming out also from the uber tires ?‍♂️ likely going in the trash
Good thing you have that huge wheel collection, you should be up and running in no time
