Refreshing and rebuilding my Baja SS
I see their out of stock at ddm for the turtle HD setup. They have the standard turtle setup
This is what I'd like to do being I already have the bonehead kit installed, so don't want to pull my brace just for his sym steer.
What servo saver setup you running?
Still running stock
If I'm doing a build like yours I would just go all out and do the sym steer
Well my next build was going to be built around the blackbone 2 speed. Then I see there are no big bores running a 2 speed since I was considering the 40gt. Might need to do another 34 reed or throw the 2 speed in my other baja and get the 40gt for this build
Dude I’m putting my 2 speed in a SF RC40. 21/53 first and 24/50 second. I’m confident it will work well.
I guess I will have to see your results since your build will be done before mines. I was on Facebook could seem to find any info with big bores and 2 speed most recommended against it
You know your right I could have sworn when they drag race the big bores they run 2 speeds
Everyone says that. I think the ratios and setup are key. I don’t any old set up works but if you are sensible I think it can.
It needs setting up on tarmac first though to get the engage point right and if you don’t go mad between ratios you should be OK. I think more than 4 teeth is an issue and I’m only going 3.
