Measure them up once and post the dimensions. They look very similar to the 5ive t body mounts. I have some spares I'd post you if they are the same size
Rick, you can just call me sean lol. Cheers.Thanks Z will do that for sure then! Wish I could run the heat shrink...just too extreme of articulation with the pinion angle and the offset transfer case. Also looks like @Seandonato73 called it correct! Even withthe check valve in the vent look what we have here. So tomorrow will relocate that for sure. Was so hoping the check would prevent that.
Also you can see this thing running 24:1 on Dominator and rich as can be...made a mess..lol.
And for sure @Seandonato73 , I would pay good $ for some nice pins with clips on them for this thing. If that pin would have dropped at speed when tuned...sure that drive shaft hitting the pavement wouldn't have just bunny hopped the rear..could have been much worse. Just gonna have to be a point to monitor. If @Haric game to make some pins w clips I'm in for a couple sets!
The pin going through the Universal joint isn't that big . Probably only about 3 to 3.5mm in dia from the looks of it. The pins it uses are hardened Steel or Stainless steel.Before you go the custom route, Why not just use a bolt like this (obviously the strongest one you can get) and use a lock nut on the other side?
Was just an example but why couldn't he use a titanium or hardened steel bolt ? Actually CuriousThe pin going through the Universal joint isn't that big . Probably only about 3 to 3.5mm in dia from the looks of it. The pins it uses are hardened Steel or Stainless steel.
This I understand. TI screws are expensive and you can't just buy 1 or 2 as needed. A hardened screw you would need to tap all the way through the universal joinf so you could thread the screw in . If you didn't do that the universal joint would wear the thread on the screw off and probably damage both then you would end up replacing the joint too. Hopefully the red loctite is enough.Was just an example but why couldn't he use a titanium or hardened steel bolt ? Actually Curious
