Got it ?This I understand. TI screws are expensive and you can't just buy 1 or 2 as needed. A hardened screw you would need to tap all the way through the universal joinf so you could thread the screw in . If you didn't do that the universal joint would wear the thread on the screw off and probably damage both then you would end up replacing the joint too. Hopefully the red loctite is enough.
