- Reaction score
- 22,962
don't you run water cooled headers like real boats? Or is it just water cooled head?
Thanks, I was unsure of how it dumped out from the engine. Makes sense.Sean
We run water cooled cylinders. BUT the way the Zenoah is a converted air cooled to water cooled engine. They must also run a water cooled adapter to cool the o-rings that are used at the pipe to engine adapter. Our engines we build have water cooling coming from under the exhaust port around the exhaust and up into the water cooling jacket. Than dumps overboard. Water cooling in the exhaust is a massive hit in power.
Judging by the cured stuff I had to get off the tube id say yea. Idk about everyone elses exhaust mine has a slip joint and im hoping my olimat pipe thats on its way is a slip joint as well because if not back to the drawing board
?oilmat is a slip on joint??
Just to report back...the coupler held for a good (benefit of doubt) 20 minutes. True losi fashion.
And do you dbxl owners...when you lose pins out of the axles body pins will NOT get you out of a jamb. Centrifugal force I supposeView attachment 64439
Does a bear ? in the woods? ?. Normally not as bad as hes had it lately, but yes they do tend to fling pins out. Tbh since I've switched over to flm shafts it hasn't been such an issue.... ymmv.Seems like the dbxl has a bad habit of flinging pins ?
You can make the pins out of partially threaded Allen screws. I think those pins are 5mm? Cut the Allen head off and the threaded part with a dremel. Then heat it to a cherry red with a torch and dip it in motor oil or waterJust to report back...the coupler held for a good (benefit of doubt) 20 minutes. True losi fashion.
