Mick Boomer
- Reaction score
- 991
- Thread starter
- #21
Which shock pistons do you run front and rear? 4 or 8 hole?
That's an unacceptable clearance issue, they should really send out a new set.I might go with the diff housing also.
If you are thinking about buying the hubs and spindle the bore on the bearings housing is too small. You need get round sander with a dremel and clean of the anodized and afterwards you need heat it up with a torch in order to insert the bearings. I will contact Steve and let him know about this issue.
Inner bore measure 31.78MM and the bearings is 32mm.
That's surprising, they must not have a particular order how they are built, or the issue was actually fixedEnded up using one shim on the bottom shaft and 3 on the vertigo shaft. Shims are 14mm od x 8mm id x .5mm thick.
The pin holes on the yokes and on the splined shaft all line up perfectly strait.
This shaft is in phase.
Cant be I just got my kit. Rear shaft is out of phase, but I haven't gotten time to mess with it as far as pin orientation.That's surprising, they must not have a particular order how they are built, or the issue was actually fixed
That is weird. My kit is a new one too and the pinholes all line up perfectly. Im sure you can get a warranty shaft.Cant be I just got my kit. Rear shaft is out of phase, but I haven't gotten time to mess with it as far as pin orientation.
Nope, contacted DDM about it, and was told it was normal for them to be a tooth out of phase ?. I'm gonna play with mine and if rotating the shaft around 180 and sticking the pin back in doesn't work it's getting welded in the right position, till the cvd comes back in stock.That is weird. My kit is a new one too and the pinholes all line up perfectly. Im sure you can get a warranty shaft.
Yep. Mine were tight as well...I put my bearings in the freezer and heated spindle they drop right in...its how they should be..I own a rzr and this is how I swap new bearings and I've done this a fews as I ride hardI might go with the diff housing also.
