Vekta.5 lse stock’ish build
Is it just me or is the vertigo tank mounts pointless? Appears that part of the mounting tabs need to be trimmed down🤷🏽‍♂️
Finished installing the motor and pipe today. Bout to Feed her some c12 klotz. Other than tuning my build is finished. My goal was to keep it stockish and I believe I achieved that.
Now just waiting on the cvd rear shaft to be in stock.....
Been awhile guys. Been to busy to do anything last several months. Anyway got an issue. My first run only about 5 min. My brake rotor is chewed up and seems like it binds every half revolution. Is this normal does it just need to break in. If I hold the rotor strait it dosent bind. Linkage is adjusted perfectly and it rolls smoothly. I honestly thought it was something in the transmission until I finally found it was the brakes binding when loose. Thoughts?
Im running the stock trans. Theres nothing I see that helps keep the disc sintered. Am I missing something?
