- Merseyside Uk
Was that an afterthought, or alx deal mark?
It comes fitted from the factory Sean, they are essential to reliably starting a big high compression engine as Zee is finding out. ?
Mark I swear to god if you say I need a goddamn decomp valve one more time I'mma loose it ??????It comes fitted from the factory Sean, they are essential to reliably starting a big high compression engine as Zee is finding out. ?
Lose is all you like lad, you deffo need one.Mark I swear to god if you say I need a goddamn decomp valve one more time I'mma loose it ??????
Now that I'd have to see???????stop fuckin about
?? Not sure if I even can with the cast head is why I haven't done one. Thinking it might m crack when they (machine shop) put the hole in it.Lose is all you like lad, you deffo need one.
Or a kick-start
Or a lifetime supply of pull starts
Just put one in you fool an stop fuckin about?
I don't think nobody asked you Doug ??Now that I'd have to see???????
You can mate, all the old rcmax 71 didn't have billet heads and had decomp valves.?? Not sure if I even can with the cast head is why I haven't done one. Thinking it might m crack when they (machine shop) put the hole in it.
As Soon as I posted my last reply I knew that was coming ????You want to go there do ya? Hey guys how did this happen? ??
I'm not thaatt dumb ?The best part is . That engine in your buggy is a gift that will just keep giving . The clutch pic is just the first of many I have a feeling.
I don't know, definitely wasn't hard to pull over with that starter.Maybe an arm?....
Yes. I can't do this myself tho, for one my tap set sucks, 2 don't have appropriate drill bits, and lastly, there's fin(s) in the way which need machining out of the way. Gunna be expensive and time consumingSo you order the decomp valve separately and you have to drill and tap it into the cylinder head?
They do, mine doesn't cuz I don't have and ALX head, just aGot you. I thought all big bores came with it.
