Z's HPI Baja PT:2
Those will not hold in an impact. Just sayin'. You need actual cable and a swaging tool to compress the end fittings with enough force to prevent them from popping off when your rig takes a tumble.
They might look nicer, but the zip ties were actually a much more effective solution.
Here's the super cheap cable version: http://beatyourtruck.com/forum/showthread.php?54250-DIY-Shock-Limiters. You can probably get away with using vice grips like this gent did rather than needing the swaging tool.
I did a bit of digging and found the real deal for ya on the cheap!
https://www.mcmaster.com/30345T165/
https://www.mcmaster.com/30345T562/
Fronts are 5" and rears are 6" eye to eye. The only difference between these and the old Killer RC version is that the coating is clear and the ends aren't dipped in plasti-dip.
I may or may not have just ordered a set accidentally...
Yup, totally ordered a set... ?‍♂️
So Doug, you can go ??? yourself ?
You never cease to amaze me Z ?
Really though, you should wait for @crucialRC to liquidate his shop ups. I'm sure he would work something out with you. Save your money until then, that's my vote
@crucial what will you be selling?
