we've sussed this already dude?thats a cut out button...not a killswitch dude?...going by thia im assuming ur running with out a kill switch then?
Ahhh not too sure about that but ur definitely welcome here ??Hey welcome . Your in good hands ??
You can still use your radio, just you won't have the function of killing the engine from the remote. It will still save you from a runaway tho ?So now I found out that the killswitch I ordered needs a 3 ch radio?! I am using a Spektrum SPM2335 so I guess I am screwed.
You're OK, that radio has the SR310 reciever which is 3 channel. Just plug the killswitch into the AUX port and you're goodSo now I found out that the killswitch I ordered needs a 3 ch radio?! I am using a Spektrum SPM2335 so I guess I am screwed.
Just checked and it does in fact have a SR310 3ch reciever. Something is already plugged into the aux port?
I had some time to mess w/it and pulled the spark plug and it sparks just fine. Still won't start...
Throttle servo is working properly and butterfly is opening. How Do I check the coil? I still think it might be flooded >
