My mcd did this...1x of the coil plugs was touching the head?..It'd start then run for a bit then cut....everytime..?.took me awhile to work it out?
Yeah my L5B did it. Had me scratching my head cause it would run great but if I hit a hard bump it would just cut off. Then when I would pull the starter to see if I had spark it would be all good until the next hard jump or bump then BAM, shut off again.My mcd did this...1x of the coil plugs was touching the head?..It'd start then run for a bit then cut....everytime..?.took me awhile to work it out?
Exactly what mine did..?...obv the different pitch in the engine vibes/bumps ect would eventually make it touch the head n cut..?..proper head scratcher??Yeah my L5B did it. Had me scratching my head cause it would run great but if I hit a hard bump it would just cut off. Then when I would pull the starter to see if I had spark it would be all good until the next hard jump or bump then BAM, shut off again.
Sweet! What fixed it?Woo hoo I got it running!
+1 now go rip it ?At least it was a cheap fix??
The trim for the throttle was turned all the way down. I turned it up a little and it fired on the first pull -man I feel like an idiot!!!
