madgreek
OK just in case anyone is interested in the T90 gear accessibility to service, swap out gearing, adjust/replace the slipper or grease the gears, I figured I'd make a little post on it. I was actually fearing having to do this to put taller gearing in mine. I thought I would have to pull the engine, exhaust, and complete T90, but I didn't.
You will have to remove the exhaust(if using a tuned pipe) to gain access to the tank mounting screws.
You will have to remove the tank(3 screws)and lines to the engine.
Remove the brake rod(loosen 1 set screw at brake cam).
Remove the 2 thru bolts for the front rear outdrive cup(attached to the front center driveshaft) and rear axle pinion where the rear telescopic driveshaft attaches to the rear axle. Then slide the rear telescopic shift forward and tape together so it doesn't fall off.
Remove 2 bolts on the top and 3 bolts on the bottom of the T90 rear cover.
Next pull the rear cover off to gain access to the gears.
Easy shmeezy and took 10min??Swap gears and reinstall. Waiting on the gears to come in now so I'll let you know what difference is once I get em installed. View attachment 58192View attachment 58193View attachment 58194View attachment 58195View attachment 58196
Going to need to remember this process as removing the T90 is a royal pain in the ass. I had to do this a few times (installing the washers etc) hoping I have no need to for a long while. Probably just jinxed myself.
