Cant get my losi 5ive t to start
+1 to TDC's recommendation. Dave's Motors are all about large scale and they're responsive to all queries. Even if they can't tune it for you for whatever reason, they will probably connect you with someone who can.
Thank u for thst info
Update put in new spark plug got it to start the small air filter was dripping in fuel trying fine tune it spitting out oil from exhaust so im one step closer hopefully thats not bad news because its used
Also the small fuel breather thing is now leaking gas out of it seal brown one any ideas how fix that
A picture would help A lot.?
Do you mean the fuel bulb?.
You can get it at DDM.
Oil is normal from exhaust.
You severely flooded it,so stuff coming out exhaust needs to be drained. If it's dripping out, tilt rc and let it drain out.
Pictures again would help.
To post here:
Next time you reply - click "attach files" button. Find picture - click on and it'll load.
To post here:
As I said drain the excess oil.
Oil spitting out while running is normal. Looks like your breather? Needs new gasket- 5T guys will know.
Pullstarter- what's the issue..
It broke then i put coil spring back on it rewound it back but it loose
Where do i get new gaskets for exhaust carb etc air filter one as well
