TLR 5b basher
Once you worked out the battery, you were getting some great top end rap out of that motor!
I'm willing to bet that the broken shaft was due toe the over extension of the suspension during the big roll. This is the reason to build some suspension limit cables. I think we need to mount a campaign to get Killer RC to start making them again for all our models.
That being said, it was a helluva nice run mate!
Was going like a bomb?
Yip the big flip landed on two wheels on the left side? deffnattly broke the shaft?‍♂️ losi has built in limiters in the arms like so???20200724_180251.jpg
Just tride to drill a hole in the shaft? drill did almost nothing ??‍♂️ as luck would have it there was just enough to grab the bit with pliers ??20200724_180106.jpg
The Losi limiters aren't quite robust enough to handle such a violent roll. They're designed to keep the shocks from overextending in a track situation, like a controlled jump. They're just PEM nuts that strike the chassis at the bottom most point of the arm where it hinges to the chassis and drive train. The arms can still flex well below that point in a roll, especially with the shock springs providing more uninhibited down force at the end of the arm.
Limiting straps are mounted to the at least the middle of the suspension arms and the shock tower to overcome any flex from the arm and ensure that the shock shaft will never over extend.
This is why you see suspension straps on full sized UHVs. The limiter "studs" just don't work in a high stress scenario.
Straps deffnattly won't hurt??? but ill make my own with dog collars/leeds??
ds
Awesome run Doug!...(y)
Those rec. connectors are easy to fix ,that is a little tab in on the brass part that isnt catching onto the plastic
inside ,I had to fix them before!...:cool:
Sucks about the shaft. Do you think the low end torque was better than the stock gearing with the 21T pinny?
Iv gone from a 58 spur to a 56 thats - 2 and the 22 pinion and thats + 2?? wasn't sure how it would pull but it felt more responsive than 22/58?‍♂️?
