- Crafers South Australia
- Thread starter
- #521
Once you worked out the battery, you were getting some great top end rap out of that motor!
I'm willing to bet that the broken shaft was due toe the over extension of the suspension during the big roll. This is the reason to build some suspension limit cables. I think we need to mount a campaign to get Killer RC to start making them again for all our models.
That being said, it was a helluva nice run mate!
The Losi limiters aren't quite robust enough to handle such a violent roll. They're designed to keep the shocks from overextending in a track situation, like a controlled jump. They're just PEM nuts that strike the chassis at the bottom most point of the arm where it hinges to the chassis and drive train. The arms can still flex well below that point in a roll, especially with the shock springs providing more uninhibited down force at the end of the arm.
Limiting straps are mounted to the at least the middle of the suspension arms and the shock tower to overcome any flex from the arm and ensure that the shock shaft will never over extend.
This is why you see suspension straps on full sized UHVs. The limiter "studs" just don't work in a high stress scenario.
Iv gone from a 58 spur to a 56 thats - 2 and the 22 pinion and thats + 2?? wasn't sure how it would pull but it felt more responsive than 22/58??Sucks about the shaft. Do you think the low end torque was better than the stock gearing with the 21T pinny?
Buggies quick ,how long does a tank last?
My part is waiting at the LHS???View attachment 61519
Woot! Good thing you didn't need to order from across the pond, right?
I thought it was just my 65 vekta. Tank last 15-20 minutes. It's crazy, like driving nitro?Tank lasts about 45mins in a small bore, my twin about 15mins and my 71 under 10mins???
