- Central New Jersey
Crucial has the ability to probably fit one up pretty nicely from his vids and projects.I wouldn't mind seeing someone try it on here
You could always just tack weld one together and have someone who is very very good at tig finish that sucker up?The problem with that is the material if you are using aluminum or titanium then the mig might not work.IDK if they make any wire that would work on those?
This would take some patience and a lot of planning but certainly doableCrucial has the ability to probably fit one up pretty nicely from his vids and projects.I wouldn't mind seeing someone try it on here
Really not a fan of either cage or shells?Why not run a team chase cage and a 5t or 5sc body shell
@Seandonato73 everlast are good mig welders. you run argon/co2 mix?Hmm... I have a everlast 140 mig lol. Been a flawless little machine. Anything I need s to weld heavier then 3/8 goes multi pass or I go get the my dads lincoln 225 ranger and stick weld it. I've done some aluminum brazing and soldering in the past, don't know why I didnt think about that.
One of the ones I have is the 140hd. I run it w the argon mix??@Seandonato73 everlast are good mig welders. you run argon/co2 mix?
i need to get a bottle for my lincoln weldpak 140hd. right now i run it without gas. it's the flux cored wire that im using. still does a good job but it's messy and the welds need to be cleaned, grinded and sanded
You know it??Nice stuff ? now u got 2 matching alx engines ??
