Ya I use that equation , look at the lower lines on the new PIX I posted it shows up to 12 hp !!I get 6.2702 hp.
The equation is
torque (ftlbs) x rpm /5252
I may be off with your rpm as the table got really fuzzy when I zoomed in, but I should be rather close for uncorrected hp.
I will look into a plug tach setup to compare what I calc and what I measure , I have NO correction factors yet.12.757 actually. Yeah that doesn't seem realistic but hey if your code is right, and my math is (it is) then that's the uncorrected hp. The engine rpm seems like a believable rpm, you could get a cheap tach to strap to the plug to verify peak engine rpm. What data are you going to use for your correction factor?
Thats me manually doing the throttle ! I need to speed up the braking and possibly run the throttle off the same servo signal timing so they are sync'ed up ? the HP is messed up somewhere thats for sure ! I need to get actual engine RPM data like I mentioned.Few thoughts for you, first it seems your rpm is rather erratic during the pull. Normally you top out rpm and apply load, seems for some reason your rpm is jumping around a lot. Second thought, and I'm not sure how it effects the readings, did you calculate for the spider gears possibly throwing you off? Idk what the split would be for running just one wheel, or what if any ratio you would use to make sure you have accurate gear ratio. I'll look into it when I get a chance. Other then that i think your set up looks good and seems to be working well, still having a hard time wrapping 12hp out of 32cc engine.
Ok did some digging into driving off one side of the rear. When you stop one wheel completely the rom of the free wheel doubles. So by this it halves your rear (ring and pinion) gear ratio. Is this how you figured your final gear reduction?
