So my failures = everyone else's success. After fighting those bolts I found you can find the correct replacements at hobbyking. Its pretty much the only place I could find the correct sizes cheap.
I have to redo the piston because a "final destination" series of events caused my piston to fall onto the concrete.
The rovan head is going in the garbage where it belongs. Never buy rovan over Rofun unless you need a pullstart as the Rofun pullstart is garbage put of the box.
Im thinking about buying a 30mm stroker from DDM but I'm gonna see if anyone can sell me one used first.
The bearings were sealed and I learned the hard way that sealed bearings will die quickly if you don't remove the seal. It ate away my case seals aswell.
Im thinking about making a case cutter with the cobalt I have because I want to knock .02 off my squish "might be able to do that with the 30mm stroker if this crank already isn't one. I haven't determined that yet". 2 to 3 weeks at most well see once the parts come in.
In terms of REED valves. Is it possible that the areaRC reed valve are standard or are they custom cus I want to get rid of a possible problem that could arise in the future. Also in terms of the intake plate. Im thinking about 3d printing a replacement then making a mould in silicone and casting it in a high temp resin material.
