New Vekta owner!
Well I am working on Haric's beautiful battery box and trying to figure out the cleanest way to mount the tach and maybe my temo sensor.I haven't made up my mind on the temp sensor yet.I also installed the Galante suspension straps.I
On another note what weight oil do you guys suggest I use for the shocks.I am still using the oem weight oil and this thing is a beast to lift off the ground so maybe 20 lbs over the stock weight give or take a few lbs.
I ordered a TGN pre-filter for the RcMax Ramair filter from DDM but the filter they suggested and sent does not fit.Are any of you guys using one and if you are which one.I have a Uni filter here that would work with the TGN but I would like to keep the Ramair if possible.
Yeaj just finishing up some small details like wiring and a few other small odds and ends.
Do any of you big bore guys use any crankcase or pull start filters?Do the big bores not suffer from debris getting into them and wreaking havoc?
I know mine doesn't but have they always been that way the new Diablo has them and I was wondering any of the other versions ever had them.I always wondered how they got around having to cool them without having cooler outside air to cool it?
