I think it kinda ruins the theme tbh, but thats just me, do what u like
, u already got the fuel filter to indicate gas feed line
Ideally you would do this for all types pipes, but in our vehicles it's kinda hard to move the expansion chamber around due to fitment constraints. You've got a bit more room in a boat to play with in these cases, stinger length and diameter can cause about the same reaction as header length. You just using the header to get max rpm out of the engine wile under a load using your specific set up. Sure wish we had an easy way to do this with our cars.Yeah definitely don't wanna put too much stress against your nice hull or the exhaust flanges and gaskets. The header needs to be 13 inches minimal from the bend in your header. I found this out with mine. Check this article:
https://www.modelgasboats.com/magazine/tech-articles-mainmenu-608/358-tuning-a-tuned-pipe
Need to tune your exhaust. 1" makes a big difference in how your engine rpm acts. There's a little bit more to these boats brother than our cars, So just saying don't just cut your header to fit. Use a copper pipe cut off tool grinder or dremel or it makes for ugly work![]()
