- Crafers South Australia
hate to admit, but took me much longer than it should have to get the turkey referencesMust be one of those blow up tukey things.....
Just the functional accent our dragon needed!today the postie fetched all the way from over the pond 4 or ryans @Rep732 pull start cable kits ,
thankyou very very much ryan, you gone above and beyond sending me these ,
best nephew ever ,
only the best for our dragon sean ,Just the functional accent our dragon needed!
thanks for that ryan ,Forgot to mention Paul fish the wire through the spool first before you strip the wire for the cable end so it doesn't fray on you
i have a set of the tall truck giant grips port,Got some bits for the vekta and for the baja today. Grabbed a set of rear irc shocks for the baja because they seem to go out of stock very fast and glad I did because they must have been the last pair Mike had. A set of 190mm madmax giant grip MXTs. Does anyone have these? They look like hostiles but not sure if the same quality . Figured they'd be better for the harder dry ground areas I bash.
