Iv been plagued with issues
first I had a leak on the carb so wasn't running right
. The I went away for a few days and took the L5b with and i had coil wire got fried
. Now iv been home fix my
and im ready to head out
I’m not sure if the 62mm option for the 35 is ready yetThe clutch mount for the crank will be for zen or Cy. What are you looking for in a clutch ? DDM offers FS racing 54mm full metal clutch w 8k spring,
https://www.davesmotors.com/FS-Racing-54mm-Full-Metal-Clutch-Shoes-w-8K-RPM-Spring
Or
Detroit Performance offers sintered steel with more sprng options
https://www.detroitperformancerc.com/product-page/fs-sintered-steel-54mm-clutch
Or
62mm option, vertigo housing and the Vertigo clutchbell and transmission
I'll be yanking the 80 from my Vekta and installing a 35 so I'll be doing this![]()
Sorry I was talkn about the losiI’m not sure if the 62mm option for the 35 is ready yet
https://www.detroitperformancerc.com/product-page/rcmax-62mm-v3-losi-complete-clutch-upgradeI’m not sure if the 62mm option for the 35 is ready yet
Mike said that setup will not work with the 35
He said very soon after launch of the new engineMike said that setup will not work with the 35
I was also curious on thatId run the 1242 on it.
Mine is on it's way will be here by lunch tomorrow can't wait
Doesn't sound like to much which fg you putting this in againIt doesn't bolt straight into an fg boys some modifications needed to the clutch Bell housing and small engine mount
Post some pics of heat you had to doDoesn't sound like to much which fg you putting this in again
Fg Baja 4x4 I have spoken to Mike he tells me that you can use the 29cc clutch Bell housing I've all ready modified mine and also will need to cut the 2 bits off small engine mount to bolt straight on to block will post some pics later as am taking to work to finishDoesn't sound like to much which fg you putting this in again
All done will bolt in when I get home laterFg Baja 4x4 I have spoken to Mike he tells me that you can use the 29cc clutch Bell housing I've all ready modified mine and also will need to cut the 2 bits off small engine mount to bolt straight on to block will post some pics later as am taking to work to finish
Fits like a gloveAll done will bolt in when I get home later
Fits like a glove
......Fits like a glove
