TAYLOR RC 35cc
The clutch mount for the crank will be for zen or Cy. What are you looking for in a clutch ? DDM offers FS racing 54mm full metal clutch w 8k spring,
https://www.davesmotors.com/FS-Racing-54mm-Full-Metal-Clutch-Shoes-w-8K-RPM-Spring
Or
Detroit Performance offers sintered steel with more sprng options
https://www.detroitperformancerc.com/product-page/fs-sintered-steel-54mm-clutch
Or
62mm option, vertigo housing and the Vertigo clutchbell and transmission
I'll be yanking the 80 from my Vekta and installing a 35 so I'll be doing this ☝️
I’m not sure if the 62mm option for the 35 is ready yet
Sorry I was talkn about the losi
Mike said that setup will not work with the 35
He said very soon after launch of the new engine
Id run the 1242 on it.
I was also curious on that
I got the new version 1242A
My twins,lol.
One is going in my 5ive B one is going in my Vekta.5 project. The carbon fiber towers are going onto my 5ive B.
It doesn't bolt straight into an fg boys some modifications needed to the clutch Bell housing and small engine mount
Doesn't sound like to much which fg you putting this in again
Post some pics of heat you had to do
Fg Baja 4x4 I have spoken to Mike he tells me that you can use the 29cc clutch Bell housing I've all ready modified mine and also will need to cut the 2 bits off small engine mount to bolt straight on to block will post some pics later as am taking to work to finish
All done will bolt in when I get home later
