Crucial 5ive B
I'm going to get the split center diff also. Which one did you go with Doug?
About the vent hole Doug, the Snappy RC vent conversion work by letting air in and out until a rollover then the checkball blocks the vent. Just like the hole in the gas cap works by letting air in and out? I have a Snappy kit here that's how I was able to check how it works.
I was gonna go a split diff but....in the end I did the modified rc center?? real happy with it ?? bout the check valve ? I learn something new evry day???
Not yet Jimbo. Gonna take her out today after I get me some crabs to eat for Labor Day holiday. I'll post up the results. Still waiting on the isolator gasket too. So using a refurbished one for now.
what exhaust are you running? have you vented your chassis side pods at all?
are you still running the 34cc with victory pipe?
that 34cc will create a lot of heat
bore some 1/2 holes in the body in front of the air filter. a tgn style air filter will also help as it can suck air from the front of the carb through the holes in the body, where as the stock air filter supplied in the kit is not great imo as it only draws air in from either side of a hot engine
