Aight, then I'm stumped Coop.? How come when I open the gas cap the tank is pressurized? Is the vent not letting enough air in? Do you have any pics of what you did?
I still don't understand then. If the tank cant vent out how is there not supposed to be vacuum in the tank? If air cant escape out the tank, then the tank would be sealed, correct?That would be my assumption. You shouldn't have a vacuum in the tank . That wont let the fuel get to the carb. The little breather vent of your should let air into the tank .
Yup, quick connects. Think they are the culprit? I was going to take them off and see if it ran better also. They were next on my list until the isolator gasket showed up.There should be minimal vaccum in the tank when running. Like next to none if the vent is working properly. If it's got pressure in the tank something is causing it what is the question. You don't have quick connects in the fuel line, or inline filter do you?
"O-way"?? What's that?The air vent is a o-way vent ,it allows the built up pressure to escape .if the vent gets dirty or plugged up ,your engine rpm's
will drop an eventually die!
The gas builds up the pressure alone ,just like a red gas can sitting ,built up pressure can also force an put pressure on
the carbs diaphragms ,an in time distort them ,an in some cases when the stuff sits at long periods of time ,the fuel
will push through an fill up in the block!
+1 one way??The fuel tank vents ,most are in the fuel cap ,but some tanks have a different type of venting device ,it is a one way rubber valve.
I think Z had installed one on his tank ,they are mostly common on weed eaters & leaf blowers!
Same issues. Hope its the isolator gasket, cause after that I don't know. Here's a video.
Doug, maybe I'm reading this wrong but Cbaker is saying the tank should vent out? How is that possible with our breather setup?? You said yourself the the breather we have only let's air in. Are you saying we have another vent that let's air out???+1 one way??
don't make your mind up before you replace gaskets and new manifold ??
Gotcha. I'm going to change the isolator and gasket and see what happens. I'll keep y'all posted.?LOL....it really doesn't matter which way ,as long as the tank can breath ,if it cant breath ,the engine wont run or it will run
crappy!
The easy way to find out if it isnt breathing ,is to fire up the engine ,if the engine starts to lose rpm's ,un screw the gas
cap ,if the engine starts to smooth out when you do ,then it is a pressure issue....![]()
?and the plot thickens...my snappy rc vent lets air out, why would it let air in?? thats just gunna add more pressure into the tank!
Line next to primer bulb is the return.
did y try a new vent? is there an air leak maybe on the tank grommet or fuel cap, don't know if that would cause this thoLine next to primer bulb is the return.
Haven't tried a new "vent" yet. I believe the isolator gasket is bad and am waiting on the delivery. Tank cap appears to be good but...did y try a new vent? is there an air leak maybe on the tank grommet or fuel cap, don't know if that would cause this tho
alright keep us updated ? if that doesn't work id get a new vent/breatherHaven't tried a new "vent" yet. I believe the isolator gasket is bad and am waiting on the delivery. Tank cap appears to be good but...
