cbaker65
Well Known Member
Just ordered a new tank/components. I will get to the end of this!
I am getting new fuel lines & new grommet for the fuel lines ,my tank is venting gas not air!....LOL
Should hold off ordering till you do manifold and gaskets......and run itJust ordered a new tank/components. I will get to the end of this!
Can always use a spare tank. I wont change anything else until the new isolator and gaskets are fitted and test ran.??Should hold off ordering till you do manifold and gaskets......and run it
if she isnt bring out the whips an chairbut she ain't getting them until she starts acting right.??
Damn that sucks bro. Your having pretty bad luck these days ???Another bummed run but not for the fuel issue. This time my damn throttle servo started acting up.?? I got about 10 minutes in then she went to full brakes. Guess I should be glad it didn't go to full throttle right? But WHY ME?? I checked to make sure my batteries were good in the transmitter and receiver. Every time I would adjust the horn it would go to full brake again. Wonder if its Savox failsafe?
I just swapped the Savox 0235 for a spare Losi I took out the Kraken. Guess I will try again tomorrow. On a side note I met a guy at the field that came to fly a FPV drone and that thing was super fast. He said he makes em. He got some footage of my 5ive and he said he would send it to me or post it on his YT channel. It looked wild.
Going back to my Vekta ??Damn that sucks bro. Your having pretty bad luck these days ?
I don't understand this ?? Why would it do that? Sounds like it's been dodge for a while??Every time I would adjust the horn it would go to full brake again. Wonder if its Savox failsafe?
Yes sirBusta rhymes goes hard on that song ???
Thanks Jimbo. This buggy used to be so reliable then all of a sudden WHAM!That’s a great vid from the drone, that’s one fast 5b ??
Hope you can get the servo sorted and that it all sorted ?
Good luck, hope.this bullshite stops!!!Thanks Jimbo. This buggy used to be so reliable then all of a sudden WHAM!
Took her out again today and.....same shite except only got a 8 min run with a lean condition at the end of it.? No fuel in the primer. Losi throttle servo worked great tho. Packed her up and took her back home. Noticed 2 things, silicone pipe coupler was torn and damn isolator was loose again. How the hell? So I replaced the coupler and clamps and tightened the isolator again.?
I also took the stock tank vent off and installed the snappy vent in the stock location. I did notice the primer bulb is now all the way full instead of 3/4. I also noticed when I press the primer bulb there is no bubbles in the return line now.?? So ready for another run tomorrow. Wish I had more time to test.
