Crucial 5ive-T
?I wonder if something broke off inside the aluminum TR air filter assembly? I will have a look tomorrow. I will also check the reed petal Z. I will post my results when I take a look. Thanks for the brainstorming guys??
Heat would make a lick of sense tho, as the case was totally blocked by grass, but you would see that (heat marks and such) in the motor like siblues said.
Wait until I finish uploading the video. I watched it like 100 times while editing and I really can't see what went wrong. Other than the crash where I bent up the wing it was a simple run and the engine sounded good. Other than a slight gurgle at take off from being slight rich. I'll post it here tomorrow too.
Hi,
Sorry for you and your engine.
Last time i saw that on a 2 stroke ( Ktm 250 exc) it was the intake pipe ( between carb and crankcase) that was porous at WOT : instantly you're hyper lean and seize the piston.
Check your intake gasket.
Hope it helps;)
Damn... Im still baffled by why would the carb go empty if it sucked something in, which would make me think that it would be lean damage but nothing really shows lean. Obr ever get back to you?
