Crucial Kraken Vekta.5
Got it in. I couldnt wait??‍♂️? First off it looks killer. If using the Axis stand mount, it will not grip around the front of the box. I will see if i can give you some measurements to possibly overcome this obstacle. Whoever installs it will need 2 grommets. Luckily I already had a couple on hand from another project. Got em from Home Depot so no biggie there. The Hilantronic throttle servo must be like 1-2mm wider than the servo you used cause it pushed the box just enough so the screws wouldn't go straight in. No biggie there either. All I had to do was loosen the servo top mounting screws a few turns then install the box mounting screws then tighten the servo screws back down. I added some foam to the bottom of the tray to protect the battery. After putting the lid on it, with the 7200mah battery I would've loved just a little bit more real-estate on top to bundle the wires and put the killer bee circuit board in it. I think a slight mod to the lid would correct this. All in all I think this thing is sick tho??and I'm geeked that I'm the 2nd person with one. Thanks Haric??
20200709_170105.webp20200709_172503.webp20200709_172657.webp20200709_173006.webp20200709_174240.webp20200709_174958.webp20200709_182454.webp20200709_183137.webp20200709_183713.webp20200709_183720.webp20200709_184003.webp20200709_184008.webp20200709_184016.webp20200709_184231.webp20200709_184240.webp20200709_185323.webp20200709_190249.webp
man I just want a Vekta so bad. I can afford it its just damn it still is just expensive. Whats the difference between the LSE and regular Vekta 5? :ROFLMAO:
The difference is... you don't have a Vekta
Afaik the only difference is that one is a kit with no electronics and one is an assembled roller. I've been known to be wrong though.
