- Crafers South Australia
- Thread starter
- #881
? they look sick?? match with the red?? brp look better??
Don't think John has a Tony green pipe?
Post a pic with it mounted in an sx5 cage will ya??I've had about 6 of those lol. Not sure I have a pic, I'll see if I have a pic somewhere.
Ok so there is gonna be a run delay? there is a leak between the reed and case? gonna see if I can fasten it with the cage in place? if I can ill take it out .......but if the cage needs to come off ill probably only get out next week ?
View attachment 70371View attachment 70372
Right? why I'm i get a ton of positive pressure in the fuel tank? came back inside and pulled the breather off and fuel rushed out like a hose??Not sure I had one with a sx5 ?
Oh, thanks for clearing things up ???That's not normal.....
Yeah carb is gunna need to come out .There's the problem ? the carb is so lose the the throttle linkage is moving the carb? one bolt missing ? top one almost out?
doug, i have this right don't i ?Right? why I'm i get a ton of positive pressure in the fuel tank? came back inside and pulled the breather off and fuel rushed out like a hose??
Yip put the clunk on the yellow hose so I could see the fuel going to the carb?? thinking about the positive pressure......was in the garden round midday ? feking hot today and car was sat in the sun for half an hour= positive pressure. The tank has no valve and I put a breather on the black pipe???the only way ya can get positive pressure in the tank is with a rise in temp,
i see in yer pics that you have the yellow pipe as feed and i presume that has the clunk on
