If you don't take a vid , you never drove it ??I am charging my batts. an getting my radio gear set up right now ,then have to install the throttle linkage ,get
it adjusted!
You got a kill switch?I need to button a few things down before I drive it ,yesterday ,I had some issues with the radio gear ,couldn't find the original
rec. ,so I had to bind another one that I had to it ,but got the radio gear working!
Here ya go Z ,a little teaser just for you!.............
Remote kill switches will kill the motor if there's a problem automatically, you don't have to do it.Yea ,my finger!....
No ,not a remote kill switch ,I will add a return spring on the carb later ,as my wrecks happen way too fast!
with the twin ring piston, Did you check to make sure that you did not have any ring end gaps that were not supported by full cylinder through full stroke.The carb needs kitted ,it will flood as it sits ,but once I open the needles up after I start it ,then it stays running ,I
remember now a few years ago ,that it was happening ,that why I quit running it ,that is why it doesn't return back
to idle ,an caused me to wreck ,that is why I was playing with the sets ,wasnt tuning!
Here is another vid. ,it is flooding ,an it is the carb. the tank is venting like it should ,so there is no built up pressure in
the tank forcing fuel!
I am quite happy that it will still run with the way the carb is ,at least I know what the issue is an it will stay running ,
but will not attempt to drive it until I get another new carb or fix this one!
do your drive axles stay in when you screw up and roll the car? I'm having a major problem with this on my 001.
What carb you going with?
I hear ya but you can swap carb over to the new engine.It is basicly the same thing what is on it now ,as I don't want to sink a lot of money into this right now ,later
I might upgrade the whole engine!
That being said ,an I don't know what it actually is ,I will just call it the Junk brand!...
It was cheap ,so if something else fails ,it wont be a loss!...
...but its a new carb??Just wait I'll reserve the I told you so for later ?
