My project 5b
job for tonight was to tackle the front and rear diffs.
First the rear diff
Not much grease in there. It’s the first time I have opened the rear diff in my ownership. ?
Rear diff almost as good as new. All gears looked in good condition which is ?
Then onto the front diff
Then all built back up. My new steering servo mount and steering setup and new rod ends ready for the assembly.?
Next job is to tackle the chassis strip down
Nice work... I've got to do the same. New aluminum diffs coming with CCR and MIP innards. I may get an upgraded rear housing too. Good detail with the pics too!
thanks Gaffle. that sounds like an expensive order you have on its way (y)
we all like racy things striped down
and don't forget well lubricated :ROFLMAO:
Lol lub hahahah :ROFLMAO:
Now this is where we're have to be careful if Z or evssv get wind of us talking about lub and strippers:oops::ROFLMAO::LOL:;)
They will get carried away and then there will be a formal inquiry:ROFLMAO:(y)
Back on topic ?
Tonight I started on the chassis
Onece the chassis was completely tore down I set to work on the center diff.
May I say that the center diff is a masterpiece
Fluid all changed an replaced 300,000
All diffs now done I can concentrate on the major clean up lol
@jimbo1 you what i.v been thinking ?
Will the centre work a as front and back? Surely?
I would need to measure up but I think the centre is longer if I remeber correctly so don’t think it would fit in the drift housings :unsure:
Thinking about it, it might be the diff cups that are longer so it might work with swapping the diff cups to front or rear ones!
Next up in the big clean up was the chassis,motor and electrics tray. I must be crazy knowing it is going to be filthy again after it’s next race day.
At least I will know everything is tip-top ??
I still have a few little jobs to do like new antenna tube and a few odds and ends
