If you can repair ??
Honestly I would have mixed them off the radio, but aside from a linkage that was adjusted wrong, I think they're sitting quartered well enough for the purpose, and it's more work than I'm willing to put in at this point. I fixed the insulator on the front one's positive with a ....for now solution, I will probably use some liquid electrical coating when I'm no longer locked in the house! It's so close to the entry to the servo that if I have to solder, I will probably open it up and replace the lead from the board. I neither feel good enough, or have the tools at the house to accomplish that at this moment.I'd just check the solder and make sure it's good then leave it. They just made a Y harness. Your going to do the same thing anyway.
I think their is a test brappp in the cards
I'll have to re assemble the stock airfilter, but I think it's oily enough. To run on the road for a few minutes. I have air filter oil coming but....yeah, plague... fun stuffYes please a test?
yes normally a rubber bit there on most pipes ?but ur pipe looks like it sits v.close to the head?....chk pics on ddm it'll show wht comes with ur pipe?Honestly I would have mixed them off the radio, but aside from a linkage that was adjusted wrong, I think they're sitting quartered well enough for the purpose, and it's more work than I'm willing to put in at this point. I fixed the insulator on the front one's positive with a ....for now solution, I will probably use some liquid electrical coating when I'm no longer locked in the house! It's so close to the entry to the servo that if I have to solder, I will probably open it up and replace the lead from the board. I neither feel good enough, or have the tools at the house to accomplish that at this moment.
She has a remote throttle and steering finally, and I think their is a test brappp in the cards for tomorrow if this cough doesn't get worse.
Bot the prettiest bell at the ball, but we're making progress, and headed the right direction at least. View attachment 69270
This pipe leaks at the junction between the header stub and the pipe. Is there supposed to.be some form of rubber coupler there to combat that?
they r generally sweet engines obr's?..jus not there 46/7?So why is the obr 46 a dog?? Yoyr the second person to say that. Thought obr was top of the game
if ur looking at the 46?....ur betrer of with the 34v2...imo?
wos the price difference between them douggy d?Or a gt40 rcmax??
Likely they didnt do much r&d on it, and the porting is shite. Its noted for overheating as well. Just a turd all around. They really should remove it off their site.So why is the obr 46 a dog?? Yoyr the second person to say that. Thought obr was top of the game
Couple 100 I rekon?
Obr 47 reed 799
Dp gt40 995
nope?the 46 is huge compared to a 34 32 ect?So while we're talking power plants here( it's my own thread, ill derail if I want!!.
Would the clutch housing from the 46 work on a 34 zenoah, or for that matter, some like an rcmax or all engine? I've been wondering that, as the pipe looks to be similar enough to work in a pinch.
I'm curious what it would actually take to mount one of the 40s, or even a g340 series, back in this truck when the 46 brapps it's lat brapp.
I'm assuming new mounting pieces( whatever we the proper term for the aluminum inserts under the chassis is).... but would the bigger clutch work?
But what you can do is stick an ALX universal clutch which is a 70mm??So while we're talking power plants here( it's my own thread, ill derail if I want!!.
