Quick baja build #100
on one side, I wouldn’t keep suck a nice engine on the shelf
On the other side, it’s so nice and rare to run
one solution: A whole new build centered around that engine 🤣
I have enough rare parts to do about half a build, but that's about it. Sourcing the rest for a rare parts build would be $$$
Wait and see if this new 2wd kraken is worth buying and drop that engine in there. If you build it they will come like in the Movie🍿
True, been waiting to see what this thing is about but they are not real keen on releasing it
Well swapped the obr out for the scott finlay. Obr is sold.
Considering selling this as well, what's everyone think I should post it for. I mean the whole baja as it sits
Yes, but if it has a bad bead seal it wont matter what you run it will blow a bead easily. Foams are to wide for the tires. Visibly you can see a width difference in tires from the uber to almost any 5ive-t size.
i got my uber tires assy’d on proline wheels but the outer beadlocks need to be replaced. they are thin like the inner ones and cannot find them anywhere. which outer beadlock rings would you recommend? ddm says “fits any beadlock” but those who used this tyre might have a different opinion
thanks for your replies
