- Crafers South Australia
Ah right with you???
When the TR System is a paired up together it dose look??
Whats the spur and pinion, where can I get one?
Did you test these yetI run 19/55 on my 34 Reed ?? just bought a new set 22/52 ? still need to test themView attachment 61439
I think it's unnecessary. The stock ones can hold rcmax 40gt power so you'll probably not have an issue.do you think it’s worth doing these gears also ? Or you think there more for 40 and up size enginesView attachment 62131
Drag racing puts a ton more load/abuse then our bashers. So that really won't happen in this applicationCheck this out ???View attachment 62132
Ddm black magic gears in a tr tranny ?
Came iut of this carView attachment 62133
I say if you have extra$$$ go for it??
I have them in my 34 reed??
Ya, stock is most likely strong enough, but I wouldn’t mind having a bullet proof diff. Think I’m just looking for a reason to spend more money on this thing. Maybe I should look at getting alloy bell crank or alloy hub carrier instead. I will just sleep on it for now make a decision by tomorrow. Sweet looking dragsterDrag racing puts a ton more load/abuse then our bashers. So that really won't happen in this application
You just jinxed yourself.......Drag racing puts a ton more load/abuse then our bashers. So that really won't happen in this application
Nailed it???You just jinxed yourself.......
