SD73's kraken vekta 5 build.
Are them swingy p or kilker rc limiters Sean, I really like them, just grabbed the Galante set the other day and not sure if I'm gonna like how they mount or that their nylon straps
I know..that's the brand or killer rc?...whatever bad typo my wrist is fooked? wheres our mod????????
⁸Short update. Hit another fricken road block. The arm that came with the hilly servo is tapped for 3mm bolts. The factory bolt and IRP drag link is 4mm. Funny all the taps I have I don't have a 4mm tap, so I had to order one. ?. Got the reciever in brakes hooked up, they are stiff as fek. Need to lube and work them a bit. May even add springs between the pads if I have some the right size. Got the steering servo mounted up using one of my old savox servos. And this is how its gonna sit for a bit. Life kinda getting in the way atm. At any rate the bench needs clean up, I have an engine @siblues sent my way, I'm gonna pop apart and see what I can do with it. Stay tuned it's getting there lol.
I bought this because wasn't sure of the arm supplied with the servo, works with the hilly too
Has the drop down nipple on it too so your servo arm link is nice and parallel, I went with a adi setup to match my big hitec, so I have that as a spare.
I stuffed my junk factory box too and the 2 times I ran my truck (and I've been very easy on it) the weight of my battery with it vibrating has chafed wires on my killer inline fuse kit and roughed up the case on the battery already. With the cost and the limited supply of the battery, rx and the killswitch systems its more than worth waiting for the @Haric box. I'm finally starting to see grass sprouting and starting to green up around here, I'll really be able to check these rcmax genesis spikes out soon???
I got some nice foam to stuff in there around the battery, just hoping till I get the engine ported and the last little tid bits done haric has time for another batch of boxes. Still have to play with the driveshaft yet, set the drag links for steering, toss the rear caster camber blocks in, and paint the dam body. May grab another set of servo clamps for the hilly, not crazy how it sits in the stock mounts. May just buy different mounts for it as well. Blowing money like crazy on this thing.
If you get the ffrc mount, I had to mill about 2mm off of one of the sides of the mount to get it to fit. Didn’t get a pic of it?
