????????????????????????He can't break stuff when it sits on a shelf ???????
Now you know how it feels dik ?????????????I break the fronts about every other tank. Normally it's just one side or the other, this last run was jumping quite a bit, and busted both the front links. Wanted to dig the one front corner in on turns after that. Guess I'm a bit particular how it handles.
So mine got ran more or less daily untill I had kids, now it comes out every now and then. It's been golden for nearly 2 gallons of fuel.... your cant make it 3 tanks without shutting its pants, I tossed a dry wall screw in and fired it back up and ran. I'm not seeing the comparison your trying to make here. A factory defect is just that, a factory defect. If I knew why the front sway bara mounts constantly broke I would dam sure fix the issue. haven't been able to come up with a good reason yet.
Ironically it's my arse hat neighbors post. I had my property surveyed and he didnt like the results. I told him he can take it to court, if he likes. So he proceeded to pound a row of T posts on the line.... hes been told to remove them, several times by our code enforcement officer. Another 2 months and I think I can pull them out. I'll be sure to use the tractor that time around.
Did someone say front sway bar links?Yeah they all more or less break the same stuff. Wish the front sway bar links wouldnt keep breaking. Tbh I may hit up @Haric and see if he can make something stronger.
I wasnt trying to hit it, I have a dirt pile i was jumping next to the property line, landed a bit goofy and gassed it, right into the T post. To be fair, I didnt notice what I did till I seen the rear dragging arse.
