I ended up pulling a tower pro from semi (945) for throttle and brake. Might as well keep the tower pros both in here until I can afford better servos. and I had a 5625 in the semio for throttle/rear brake. so I opened the second 5625 up, reversed the wires on the board and motor so it spins opposite and mounted in the semi tray...
I have a v2 failsafe so decided to use the nutech radio. long story short, the nutech radio won't work with tower pro servos. not even a glitch. nada. I installed the spektrum and the servos are fine
so I have a 6000 mah 2s maxamps lipo, turnigy 15 amp
bec (with power bar to show battery life) installed. we are going to setup a track this weekend. it's forecast for sun saturday and sunday, even if we have snow farecasted for the week. should be clear enough anyway. I have 22/42 gearing, should be ok with the f1 tires but I have a 20/44 combo to toss in if need be.
vw is complete now aside from needing a kill switch. I'll toss this kill switch in the f1 and use the nutech radio on that. semi is down waiting for parts. and the leftovers I put a bunch aside for the mercedes build and another pile on the marder chassis.
anyone need a marder chassis with some alloy front bulkheads and tower, carbon steering top plate. firehammer mt arms, plastic motor mount, rear bulkheads and shock tower?
