wow its almost as if someone has already said that. good job my little parrotNo the return line is on top the feed line is bottom
nobody. it meltsWho uses loctite on the exhaust bolts?
cool story broI was typing before you
And he thumbs up mine meaning I am da man and you are not
nice jobIt gets too hot so no
Bonehead holes are not lined up at all. This engine was setup for baja on the clutch housing. Can someone tell me what mm the clutch housing is supposed to be?
my micrometer is showing 29mm
Bart stacks look nice. Definitely smooth
Ah right now I see the cf chassis uber?It isn’t noticeably heavy. But total weight of my baja is definitely noticeably lighter.
