Winter build Hpi 5b
Bonehead holes are not lined up at all. This engine was setup for baja on the clutch housing. Can someone tell me what mm the clutch housing is supposed to be?
my micrometer is showing 29mm 😡
Everything needs to be loose, it will work just move stuff around a bit.
You da man also John. Insane how tight everything was. But you’re right. Loosen everything up and It barely went together. Not done yet though
