Im too paranoid to go out of my garden with out it working properlySorry, I have the Killer B kill switch but haven't installed yet. Wish I could help.
Thanx for the effortI just threw in a sr415 I have as a spare to try and duplicate whats happening with yours.
I have the kill switch plugged into aux 1 on the reciever. Aux 1 is assigned to the ROSS button next to the scroll wheel on the transmitter.
If the engine is running..i push the button and the engine shuts off.
Iv check all other possible options the coil is the next stop. Was trying to avoid taking out the motorI do not have a kill switch but it sounds like the kill switch is setup with the receiver correctly but maybe isn't breaking the ignition circuit properly. Double check that you are in fact connected to the correct ignition wires you can possibly test this without the motor running with a power source and volt meter to see if the switch is in fact breaking the circuit to its connectors.
thats how iv set it upI see that you have the Spektrum DX4s. This radio has a fail safe system that is not programmable. If the receiver is on and you turn off the transmitter then it should automatically put it into full brake. There is no way to make this radio use a fail safe function to kill the vehicle if it looses signal from the radio.
