- 27,691
- Thread starter
- #941
well then your going to have to believe me then . because there a good bit of wobble, period. everything else in my setup is perfect. no slop in any bearings, no fiddlesticked up mounts or bent chassis. this is literally all there can be. last time i put it back together (2 weeks ago or so), i remember the gear mesh going in sand out, in one spot it was loose (like you saw), and on the other side it was quite tight (could feel it too) . at that time i was pissed off and thought maybe it would just break in, obviously it didnt. its gotta be that clutch bell. and you guys saying "theres too much slop in your mesh" or "something is messed up in your setup" without any suggestions or redundant ones aint helping jack poop. nor is the few bs'ers who hang around my thread just to laugh at my issues (you know who you cunts are) . rant overYou need to go back about 20 or so pages to the last time you ate a Spur gear. You had to much slop between the gears and never corrected it . Until you get a better mesh you are just going to keep eating gears Z. I really couldn't see any wobble in your pinion gear/shaft . Any wobble I saw was induced by your palsey causing your camera to shake.
