brokestroke
- Reaction score
- 219
- Thread starter
- #201
I take it you’ve got a diff locker?Baja transmission fits roughly, needs to be dropped 1" to line up the shafts better.
Are you making it front wheel drive or are you going to build a crazy drive system to drive the rear?
I’ve seen you’ve gone with plastic too, not so sure about that.
Can you explain how you will power both ends with setup you’ve shown?Going to be four wheel drive with a front and rear driveshaft.
Uncertain if I want to lock the baja diff or use heavy weight oil.
Can you elaborate on the side load issue? Plan on making the mount from steel and there will be zero flex in the motor or transmissionif i was you and since your already outside of the box stop looking at hpi exclusive parts because your creating more work for yourself and the parts your buying are not ment to work in the way your brain is thinking..im not for this build as there is no pride in your work but it bothers me seeing you building it in this way.. refine your chassis into a single plate and make it look as it should if it came out of a box
It’s not obvious to me, but then again I’m a bit thick.
So your trans mounts from the side of transmission case which will produce stress on mounting since its not inline with the rotational force also with a baja im sure it is secured from the back and underneath. A 5ive t center diff would of been a better option and this is technically the "transmission" on a 5ive t and its simple and only one 1 gear and its only bolted from the bottom
Integrate a spur carrier into the mount.and now were back to the , are you gonna support the spur with a carrier question ?
you will melt a plastic case and/or eat tranny bearings without one,
and how are ya gonna have brakes et up ?
Hopefully granite. I have other plans for the future and want the extra gear reduction of the baja transmission.So in reality here your re-inventing the rock?
just a bit of advice from me mate,
if you really want to continue with this build, if i were you i'd take a step back, or a couple of steps back,
ditch the chassis you have now, start afresh on the chassis, 6061 will be fine for a flat chassis,
i made my own extended chassis for my dragon hammer out of 5mm 6068 t6, added two small kick ups at the outer edges to help stiffen it, a copy of the original but 35mm longer and slightly reshaped/ pocketed to lose weight,
then if you bolt down the baja gearbox as it should be, reposition the engine and use a baja gear plate to get the mesh right on the gears,
make or modify a stock baja tranny plate so yer brakes work, and also that will add something to add braces for the chassis, gearbox, engine etc from, link everything together with braces etc,
your centre drive shafts are gonna be an issue, you will need to make some up, baja outdrive to savage at the front/rear diffs,
i've made shafts before and they need to be straight as possible, cut and shut the two drives of the shaft , add a press fit sleeve in beteen the two halves and weld around, tidy up the welds, cross drill where the shafts meet inside the sleeves then plug weld so everything is joined and strong as can be,
tidy up the welds and double check all is straight,
just some advice thats all,
edit; also add the front/ rear sections of the baja rear bulkhead to support a baja tranny plate,
