brokestroke
- Thread starter
- #221
I agree it's not pretty, but it should be functional. Flux-cored MIG wire always looks like a pile of bird poop when it still has the slag on it.That is the ugliest divorced transfer case i have ever done seen
Agreed. I have the bearing support that came with the brake assembly, just need to install it.You need something to support the layshaft ,it's gunna destroy the case and gears that way
Definitely a wear item, how long they last is TBD. Picture makes it look worse than what it is. The front shaft may be a different story.Also that rear drive shaft angle is gunna chew up the shaft pins or the drive cup
Yeah, I totally agree. How long they last is TBD, mostly has to do with driving style. Easy to replace though, especially the Savage drive cups.Um my 5ive t 2.0 is at factory angles for the front drive shaft and the pin is being chewed up due to the geometry. So no its going to be a wear item indefinitely for you
Nah mine was way cleaner, atleast it wasn't booger welded together with rust everywhere ? atleast it was built with good part. And i wasn't claiming it was something it wasn't (like op trying to pass it off as a 1/5 ??This thread just gets better every time I pop in. Z you have some true competition here . This is right there with your Big Bore Franken motor you tried to build from scratch. And Brokestroke is just as stubborn as you.
2wd single axle std cab, air ride 196"wb.In what trim sean? Single,ex cab,crew cab? 4x4 or 2wd? My international 4700 had a gvw of 36k lbs and it was crew cab 2wd with a double frame
Fek that, bet it was a gas hog! We can get the gvw lowered to a certain extent here, just need an enhanced inspection and a bit of paper work. Air brake muddy the water to an extent, but that's just an issue of a license endorsement for the driver, and dot physical normally. You know standard dumbfuckary stuff we do in Pa.Here's a plot twist sean.. it was a 9.0 liter v8 n/a air brake/ air ride rear with 36k lbs gvw? dmv wouldn't let me go lower after they ran the vin
