KevTrem
1820 rpm on the head the engine is running at 12,503rpm. At 2000 headspeed it would be running at 13,740. On a heli I can tell you from experience a 200rpm increase does change tune a bit if you want peak power. I am tuning by ear and power delivery as well as checking the plug. It is not lean now but will be if I increase rpm or the air temp lowers etc. I am putting new gaskets on the engine between the carb/insulator/engine next week and will test again. If nothing
No because we use what is called a governor. It controls the throttle electronically through the servo to maintain a steady rpm that you set.
What I meant by free revving was the heli blades won't give a load on the engine like the transmission and mass of the land based models.
It takes a lot less effort to rotate a blade in the air than it does to rotate a wheel in contact with the ground.
On my 30DNT, I had the high needle 2.25 turns out on a 668 carb for it to run right, then I found I had an air leak.
I replaced the gaskets and checked isolator and now it runs a pinch past 1.5 turns out.
