Fs racing thread
stipped engine hole
or put a longer bolt in it and a lock nut on the end. Hillbilly engineering. (if its a through hole) Also they make thread inserts to solve this. your local auto parts will have this perhaps.
imex has several bonuses when ordering like shipping and a hundred bucks off plus they have the best customer service around. i will not do business with flyby night importers.if you are buying a chinese rc make sure you get it from a reputable dealer.plus imex usually has all parts in stock!
fsracingusa is located a hour or so from my house so I am not to worried about parts support.
Hi you can also get your parts from
www.conrad.nl
its all in dutch but i can help you out there mucker if you need anything let me know also you can go to the German site they have them to
www.conrad.de
oh i also noticed that your rose joint on the steering hubs the off set ones are the wrong way around they should be acting as a steering stop
I'm unsure what part you mean? damn china assemble, I guess it needs to come apart, I was going to dye the red anyway.
www.conrad.nl
www.conrad.de
can you pm the prices for your hopup parts?
desperatly need
Does anyone hav a set of fs buggy wheels and tires fer sale I need a set I have the hpi adapters but they keep spinning the set screws,I don't no wat else to do,I need help. Thanx. :helpsmilie:
Fsracingusa.com should have tires, I don't know much about the adaptors, it is a flat serface for the set screw to sit? Some pics would help
Grind flat spots on the bottom of the set-screws. Use blue loctite and a good allen/hex driver that you can really wrench down on. Lots of torque will hold them in place. You may have to grind flat spots in the adapters where the set-screws touch.
Good luck!
